GRASS 6.0
Heads up digitizing with v.digit
screenshot: O. Dassau
Buffering with v.buffer
screenshot: R. Blazek
Overlapping polygons
Overlapping polygons input from Shapefile (or any other OGR simple feature format)
Result (areas colored by number of overlapping areas, categories of layer 1 and 2)
Example of import and use in GRASS
  # GRASS 6.0:
  v.in.ogr dsn=./shp/ layer=fire output=fire_p
  v.category input=fire_p output=fire_c type=centroid field=2
  echo "create table fire_c_2 (id int, num int)" | db.execute
  v.db.connect map=fire_c driver=pg database=bridge layer=2 table=fire_c_2 key=id
  v.to.db map=fire_c layer=2 option=cat col1=id
  v.to.db map=fire_c layer=2 qlayer=1 option=query col1=num qcol="count(*)" type=centroid
Number of overlapping features is also written as category to centroid.
Another example of overlapping features in one layer (overpass)
Vector overlay using v.overlay
Input A and B
intersection (operator=and)
union (operator=or)
not (operator=not)
exclusive or (operator=xor)
Charting using d.vect.chart
Pie chart
Pie charts (default)
Bar chart
Bar charts (ctype=bar)
Network analysis
d.path
Shortest path using d.path
v.net.iso
Split network into bands using v.net.iso
v.net.alloc
Allocate subnets using v.net.alloc
