# CMake module to search for PostgreSQL library # # pg_config is searched for in POSTGRES_CONFIG dir, # default /usr/bin # # If it's found it sets POSTGRES_FOUND to TRUE # and following variables are set: # POSTGRES_INCLUDE_DIR # POSTGRES_LIBRARY IF(WIN32) IF (NOT POSTGRES_INCLUDE_DIR) FIND_PATH(POSTGRES_INCLUDE_DIR libpq-fe.h /usr/local/include /usr/include) ENDIF (NOT POSTGRES_INCLUDE_DIR) IF (NOT POSTGRES_LIBRARY) FIND_LIBRARY(POSTGRES_LIBRARY NAMES pq PATH /usr/local/lib /usr/lib) ENDIF (NOT POSTGRES_LIBRARY) ELSE(WIN32) IF(UNIX) SET(POSTGRES_CONFIG_PREFER_PATH "$ENV{POSTGRES_HOME}/bin" CACHE STRING "preferred path to PG (pg_config)") FIND_PROGRAM(POSTGRES_CONFIG pg_config ${POSTGRES_CONFIG_PREFER_PATH} /usr/bin/ ) # MESSAGE("DBG POSTGRES_CONFIG ${POSTGRES_CONFIG}") IF (POSTGRES_CONFIG) # set INCLUDE_DIR EXEC_PROGRAM(${POSTGRES_CONFIG} ARGS --includedir OUTPUT_VARIABLE PG_TMP) SET(POSTGRES_INCLUDE_DIR ${PG_TMP} CACHE STRING INTERNAL) # set LIBRARY_DIR EXEC_PROGRAM(${POSTGRES_CONFIG} ARGS --libdir OUTPUT_VARIABLE PG_TMP) SET(POSTGRES_LIBRARY ${PG_TMP}/libpq.so CACHE STRING INTERNAL) ENDIF(POSTGRES_CONFIG) ENDIF(UNIX) ENDIF(WIN32) IF (POSTGRES_INCLUDE_DIR AND POSTGRES_LIBRARY) SET(POSTGRES_FOUND TRUE) ENDIF (POSTGRES_INCLUDE_DIR AND POSTGRES_LIBRARY) IF (POSTGRES_FOUND) IF (NOT POSTGRES_FIND_QUIETLY) MESSAGE(STATUS "Found PostgreSQL: ${POSTGRES_LIBRARY}") ENDIF (NOT POSTGRES_FIND_QUIETLY) ELSE (POSTGRES_FOUND) #SET (POSTGRES_INCLUDE_DIR "") #SET (POSTGRES_LIBRARY "") IF (POSTGRES_FIND_REQUIRED) MESSAGE(FATAL_ERROR "Could not find PostgreSQL") ELSE (POSTGRES_FIND_REQUIRED) MESSAGE(STATUS "Could not find PostgreSQL") ENDIF (POSTGRES_FIND_REQUIRED) ENDIF (POSTGRES_FOUND)
