$Date: 2008-02-26 03:58:34 +0100 (Tue, 26 Feb 2008) $ NOTE: Please improve this list! Dear (new) GRASS Developer, When submitting documentation to GRASS SVN repository, please take care of following rules: [ see SUBMITTING for C hints ] [ see SUBMITTING_SCRIPTS for shell script hints ] [ see SUBMITTING_TCLTK for tcl and tk hints ] [ see SUBMITTING_PYTHON for Python code hints ] 1. Editing of HTML pages To avoid insertion of too complicated HTML tags (see also below), we strongly suggest to use a plain text editor rather than a HTML editor for editing. 2. Module manual page: Place the documentation in HTML format into 'description.html'. The easiest way to do this is to study an existing HTML page (to get the page style, e.g. vector/v.to.db/description.html). With a few exceptions header and footer are NOT allowed. You can add figures (PNG format), the figure name prefix should be the module name. See raster/r.terraflow/description.html for an example. Note that the parameter information is auto-generated upon compilation. This is done by running module in a virtual session after compilation (see the output of 'make'). To subsequently verify the final HTML page, check the resulting HTML pages which will be stored with the name of the module. Examples (please add some) should be coded like this:
v.to.db map=soils type=area option=area col=area_size unit=h
