$Date: 2008-01-06 12:42:32 +0100 (Sun, 06 Jan 2008) $ NOTE: Please improve this list! Dear (new) GRASS Developer, When submitting TCL and TK SCRIPTS to GRASS SVN repository, please take care of following rules: [ see SUBMITTING for C code hints ] [ see SUBMITTING_SCRIPTS for shell script hints ] [ see SUBMITTING_DOCS for documentation ] [ see SUBMITTING_PYTHON for Python code hints ] 1. Use the directory structure to place your program appropriately into the source tree - general grass tcl/tk libraries and reusable code go into lib/gtcltk - user interfaces go in gui/tcltk - scripts go in scripts/ Programs here must have a proper Makefile and description.html 2. Add a header section to the script you submit and make sure you include the copyright. The purpose section is meant to contain a general overview of the code in the file to assist other programmers that will need to make changes to your code. Example (fictitious header for a script called r.myscript) : ############################################################################ # # MODULE: r.myscript # AUTHOR(S): Me # PURPOSE: Calculates univariate statistics from a GRASS raster map # COPYRIGHT: (C) 2005 by the GRASS Development Team # # This program is free software under the GNU General Public # License (>=v2). Read the file COPYING that comes with GRASS # for details. # ############################################################################# The copyright protects your rights according to GNU General Public License (www.gnu.org). 3. PLEASE take the time to add comments throughout your code explaining what the code is doing. It will save a HUGE amount of time and frustration for other programmers that need to change or understand your code in the future. Many of the programmers working on grass are not heavily invested in tcl and tk, so extra documentation and explanation are greatly appreciated. 4. Test your program with both tcl/tk 8.3 and tcl/tk 8.4. 5. Always use the gettext macros with [G_msg "..."] for user messages. The string must be quoted using quotation marks, not braces, for xgettext to find it. The string cannot include variable ($) or command ([...]) substitutions. If you need substitutions use [format ...]. Examples: button .ok -text [G_msg "Ok"] set statusbartext [format [G_msg "Monitor %d running"] $monitor_number]] Use positional parameters if substitutions might be rearranged in another language: format [G_msg "We produced %1\$d units in location %2\$s"] $num $city format [G_msg "In location %2\$s we produced %1\$d units"] $num $city 6. Use "GRASS_TCLSH" and "GRASS_WISH" environment variables instead of "tclsh" and "wish" at the start of Tcl/Tk scripts. This allows users to override the default names, so that developers don't need worry about the shell names. Tcl script: #!/bin/sh # the next line restarts using tclsh. Note the backslash: \ exec $GRASS_TCLSH "$0" "$@" Tk script: #!/bin/sh # the next line restarts using wish. Note the backslash: \ exec $GRASS_WISH "$0" "$@" 7. Do not source files that have already been sourced. gui.tcl sources: options.tcl select.tcl gronsole.tcl If your code requires something to be sourced before it note so in a comment at the top of the file. 8. Set tabstops in your editor to 8 spaces. When modifying files use the indentation style that is already present. Please use consistent indentation style in your new code. Whether you use tabs or spaces to indent please be consistent. Where tabs and spaces are mixed please remember that a tab is 8 spaces. 9. Use the tk options database to control the appearance of your user interface. In general do not set options on tk widgets unless that option is truly specific to that widget. It makes them harder to customize. Example: Don't set options like -foreground or -background or -font when creating widgets, unless there's a really _really_ specific reason to have it that color (like it's demonstrating that color). If you want something like a label to look different than everything else of that class (other labels) give it a distinctive name, like .moduletitlelabel . If you have a bunch of them give them all the same distinctive name. This allows them to have their options controlled by the options database. You can put your options at the start of your script (before creating any widgets) like this: option add *modultitlelabel.background red More examples are in lib/gtcltk/options.tcl Many common options, like font, background and foreground colors, highlighting, scrollbar colors, and help bubble appearance are controlled by options.tcl. You can include it at the start of your script with: source $env(GISBASE)/etc/gtcltk/options.tcl 10. Avoid using global variables. Thay are a frequent source of bugs, make code harder to understand, and make your program difficult to reuse. Additionally, putting code into procs usually makes it run faster (it gets compiled). 11. For consistency, use README rather than README.txt for any README files. 12. Use of GRASS commands in shell wrapper. Any GRASS program run in an xterm (those which do interactive query) needs to use grass-run.sh, e.g.: exec -- $env(GISBASE)/etc/grass-xterm-wrapper -e $env(GISBASE)/etc/grass-run.sh g.proj ... You should probably also use "-T g.proj -n g.proj" to set the title back (otherwise it will be "grass-run.sh", which isn't particularly informative). The xterm will close as soon as the command completes (whether it succeeds or fails). You can use the -hold switch to retain the xterm window after the command completes, but you should only do that for debugging; having to manually close the xterm window each time would be annoying in normal use. Alternatively, redirect stdout/stderr to a file, to catch any error messages. 13. Be sure to develop on top of the LATEST GRASS code (which is in SVN repository). You can re-check before submission with 'svn diff': Be sure to create unified ("diff -u") format. "Plain" diffs (the default format) are risky, because they will apply without warning to code which has been substantially changed; they are also harder to read than unified. Such diffs should be made from the top-level directory, e.g. "cvs diff display/d.vect/main.c"; that way, the diff will include the pathname rather than just "main.c". 14. Tell the other developers about the new code using the following e-mail: grass-dev@lists.osgeo.org To subscribe to this mailing list, see http://lists.osgeo.org/mailman/listinfo/grass-dev 15. In case of questions feel free to contact the developers at the above mailing list. http://www.grass-gis.org/devel/index.php#submission 16. Try to evaluate things only once. Tcl compiles the program to bytecode which can be interpreted fairly quickly. If there are strings that must still be evaluated tcl must parse and either compile or interpret them each time they are encountered. In general this means put braces around expressions and especially regular expressions (Tcl also compiles regular expressions). Multiple evaluation can also lead to bugs. Expressions via expr command: Slow: set y [expr $a * $x + $b] Fast: set y [expr {$a * $x + $b}] Expressions in conditions: Slow: if [...] {... Fast: if {[...]} {... Regular expressions: Very slow: regex "x(\[0-9\]+).*not" $string trash number Fast: regex {x([0-9]+).*not} $string trash number If you really want speed: If a regular expression needs to be constructed from variables but used multiple times store it in a variable that will not be destroyed or changed between reuse. Tcl stores the compiled regex with the variable. 17. You might want to decompose lists in a somewhat easy way: Difficult and slow: # Make x1 y1 x2 y2 the first four things in the list set list [commandMakesList] set x1 [lindex $list 0] set y1 [lindex $list 1] set x2 [lindex $list 2] set y2 [lindex $list 3] Easier and faster: # Make x1 y1 x2 y2 the first four things in the list foreach {x1 y1 x2 y2} [commandMakesList] {break} Be sure to include a comment as to what you are doing. 18. Use the Tcl list functions (list, lappend etc) for manipulating lists. For example, use: set vals [list $foo $bar] rather than: set vals "$foo $bar" The former will always create a list with two elements, adding braces if necessary, while the latter will split $foo and $bar into multiple elements if they contain spaces. Additionally the first is faster because tcl is not internally converting between strings and lists. A related issue is to remember that command lines (as used by exec and open "|...") are lists. exec behaves like execl(), spawnl() etc, and not like system(). Overlooking either of these points is likely to result in code which fails when a command argument contains a space. 19. Tcl C library: Memory allocated with Tcl_Alloc (such as the result of Tcl_Merge) must be freed with Tcl_Free. This means that the ->freeProc of an interpreter when returning a string using Tcl_Merge should be TCL_DYNAMIC. Incorrectly freeing memory with glibc free will cause segfaults in Tcl 8.4 and later. 20. When submitting new files to the repository set SVN properties, e.g. svn:executable : * svn:mime-type : text/x-tcl svn:keywords : Author Date Id svn:eol-style : native See http://svnbook.red-bean.com/en/1.4/svn.advanced.props.html ... [please add further hints if required]
