DESCRIPTION
i.lmf calculates the Local maximum fitting of a temporal time-series, intially for vegetation indices, it also works for surface reflectance.
This is a first level port, only a fast fitting is done, see TODO.
NOTES
Original links are found here
SAWADA, 2001:
http://www.affrc.go.jp/ANDES/sawady/index.html
NAGATANI et al., 2002:
http://www.gisdevelopment.net/aars/acrs/2002/pos2/184.pdf
Yann Chemin and Kiyoshi Honda repaired it and ported it from SGI/OpenMP to Linux.
http://www.rsgis.ait.ac.th/~honda/lmf/lmf.html
TODO
Port the full detailed algorithm from Fortran, and vastly unemcomber/clean it.
It will make the algorithm must slower though, gaining only a marginal fitting strength, for my actual experience with VIs curves.
SEE ALSO
AUTHORS
Yann Chemin, International Rice Research Institute, The Philippines
Last changed: $Date$
