![GRASS logo](grass_logo.png)
NAME
r.inund.fluv - Creates a fluvial inundation map given an high-resolution DTM and a water surface profile
KEYWORDS
Automatic procedure to compute a fluvial inundation map
SYNOPSIS
r.inund.fluv
r.inund.fluv help
r.inund.fluv DTM=string W_S_PROFILE=string RIVER=string FLOODING_MAP=string [DOUBT_MAP=string] [PROFILE_T100=string] [(null)=float] [delta_x=float] [river_boundary=string] [boundary_type=string] [res_B=integer] [res_C=integer] [MAP_W_S_PROFILE=string] [--overwrite] [--verbose] [--quiet]
Flags:
- --overwrite
- Allow output files to overwrite existing files
- --verbose
- Verbose module output
- --quiet
- Quiet module output
Parameters:
- DTM=string
- Input DTM raster map
- W_S_PROFILE=string
- Input ASCII file of the water surface profile
- RIVER=string
- Input vector line map of river-axis
- FLOODING_MAP=string
- Output: name of flooding map
- DOUBT_MAP=string
- Output: name of doubful surface areas
- PROFILE_BOUNDARY=string
- Input ASCII file with water-depht for return period T > 100 years
- delta_z=float
- Input delta_z to find the boundaries of the main channel [default value 0.5 m]
- delta_x=float
- Input delta_x to find the boundaries of the main channel [default value 3.5 m]
- river_boundary=string
- Output vector boundaries of the main channel
- boundary_type=string
- Format of vector boundaries of the main channel
- Options: line,points
- Default: points
- res_B=integer
- Input value: resolution B [default value 10 m]
- res_C=integer
- Input value: resolution C [default value 20 m]
- MAP_W_S_PROFILE=string
- Output vector point map of the water surface profile
DESCRIPTION
r.inund.fluv - This command allows to obtain a fluvial potentially inundation map given a high-resolution DTM of the area surrounding the river and a water surface profile calculated through an 1-D hydrodinamic model.
The implemented procedure has innovating characteristics; even if it remains substantially one-dimensional, it takes into account the two-dimensionality of territory and inundation phenomena, adducing hypotheses that let to correct many errors typical of one-dimensional usually employed procedure. With respect to a two-dimensional model, it has advantage that it needs a lower computational effort, that allows to apply it to river reaches very long (of the order of 100km).
The single phases in which the procedure is divided, are here summarized, even if the whole procedure is excecuted automatically.
- In the first phase, the value of water level in the nearest point of fluvial axis is assigned to each pixel of terrain, through the creation of Thiessen polygons (r.surf.idw setting npoints=1) (at the resolution res_B). Then the procedure makes a comparison between elevation of each pixel and water level, and defines pixels characterized by elevation lower than water level, at hazard.
- In the second phase, the procedure removes all the areas previously defined at hazard but not connected with the river axis, i.e. surrounded by terrain not at hazard, neglecting infiltration or underground rivers (v.select).
- In the third phase, the hypotesis is that water diffuses from river to the surrounding areas only in direction perpendicular to the river axis. Through an implemented fortran code (clean_inundation.f90), the procedure individuates the pixels, considered at hazard at the end of phase 2, inundated for sure by water; hence it dries the ones, considered at hazard at the end of phase 2, not reached by water because protected by levees or small hills posed along the perpedicular path between the pixel and the river axis (at the resolution res_C).
- In the fourth phase, the hypothesis is that water, outside the main channel, moves along the maximum terrain slope direction. First, through an implemented fortran code (find_main_channel.f90), the procedure individuates the "boundaries" of the main channel. Then, through an implemented fortran code (2d_path.f90), the procedure individuates the water path outside the main channel along the maximum terrain slope direction (at the resolution res_C). Finally, through an implemented fortran code (correction_from_path.f90), the procedure individuates the pixels, dried at the end of phase 3, connected to a water path, and defines them at hazard (at the resolution res_B).
- In the fifth and last phase, the final potentially inundated map is defined as sum of areas at hazard in the third and fourth phases.
Use
Requested input and output:
The command requires some input:
1 - a Digital Terrain Model (DTM, DEM or DSM) of the area surrounding the river; an high-resolution DTM (e.g. 5 x 5 m or higher) is required to describe levees and other human infrastructures on the floodplain.
2 - an ASCII file describing the water surface profile along the channel axis, in this format (e.g.):
411815.62874469644 4944870.642304279 197. 104
411848.8162966241 4944958.868788462 196.96 103.933*
411882.0010118869 4945047.096337882 196.89 103.866*
411915.188102181 4945135.322989558 196.82 103.8*
where the first column is East-coordinate, the second is North-coordinate, the third is the water level in each cross-section, and the last one is the name of the cross-section. The distance between two cross-sections is suggested to be less than 100 meters.
3 - a vector line describing the river axis from upstream to dowstream.
The output are:
4 - the fluvial potentially inundation map;
5 - the area in doubt, i.e. areas which could be at flooding hazard because of their elevation, but aren't defined at hazard at the end of the procedure.
WARNING -
The original resolution of DTM must be high. If the pixel dimension is greater than 5 m, the command informs the user with a warning message; however the procedure runs.
Optional input and output:
The command has some input parameters that the user can choose in the Optional parameters & maps interface. They refer to intermediate phases of the procedure, described in detail in reference.
1b - It's possible to set another water surface profile associated with a return period of 100 years or greater, from which the procedure starts to find automatically the "boundaries" of main channel. The file format is as mentioned above for the input file 2.
2b - It's possible to set a delta_z different from the default value (0.5 m), as the step with which the procedure increases the water level inside the main channel, to find automatically the "boundaries" of main channel itself.
3b - It's possible to set a delta_x different from the default value (1.5*DTM_resolution in meters), i.e. the threshold value of the distance between the points individuated on a bank in two consecutive steps, to exceed so that the procedure may define the "boundary" of main channel in a pixel between such two points.
4b - The user may view the "boundaries" of main channel, to verify the working of the procedure, especially if delta_z and delta_x were setted different from the default values.
5b - 6b - The procedure performs some calculations using resolution different from the DTM one. The default values of 10 and 20 meters, used in different steps of the procedure, are a compromise between computational speed and consistency of output map. It's suggested that only the expert user modifies such values.
7b - The user can view a vector point map of the water surface profile along the river axis.
(GRASS Shell Script)
AUTHORS
Roberto Marzocchi, SUPSI, Switzerland e-mail
Bianca Federici, University of Genoa, Italy e-mail
Domenico Sguerso, University of Genoa, Italy e-mail
REFERENCES
- Federici B. & Sguerso D. (2007). Procedura automatica per la creazione di mappe di potenziale inondazione fluviale. Bollettino SIFET, n. 4.
- Marzocchi R., Federici B., Sguerso D. (2008). Procedura automatica per la creazione di mappe di potenziale inondazione fluviale in GRASS: il modulo r.inund.fluv. Under revision for the pubblication on Atti del IX Meeting degli Utenti Italiani di GRASS - GFOSS.
- Pdf presentation of the work at the "IX Meeting degli Utenti Italiani di GRASS - GFOSS": web-page
Last changed: $1 July 2008 17:10:00 CET $
